773 cam in bog standard engine
Anybody had any experience with the 773 cams in a standard 1.3 / 1.4 engine.
I know people have problems with poor running with the standard ECU, but I'm running a fully mappable DTA, 4-1 exhaust manifold and high flow inlet manifold.
I'm fully aware skimming the head to increase the compression will help, but 264deg duration isn't huge and can't see it having a major effect.
From my other engine testing, I only found about 3% more torque increasing from 10-1 to 11-1cr on a 270 duration camshaft. However it was on a 8v a series engine.
