1994 Nissan March HK11 1.3 NCVT Wiring Diagram
CMF_baguete
Hi, does anyone have a 1994 Nissan March HK11 1.3 NCVT Full Wiring Diagram? I will do a complete swap of Nissan March gear to a SuperS, along with a CVT to Manual conversion, a wiring diagram would make some things easier. Thanks
CMF_Doom
I am pretty sure that the wiring will all work, except you will need to rewire the reverse lights to work and also the park and neutral start switch.. apart from that it should be good to go
CMF_baguete
Doom WROTE:
"I am pretty sure that the wiring will all work, except you will need to rewire the reverse lights to work and also the park and neutral start switch.. apart from that it should be good to go
I cant seem to find the ncvt inhibit relay, need to check where the wires go...
