160sr ecu
R
RIK
erm..........wheer is it?
i thought i found it between the handbrake and gear lever untill i seen "srs air bag" + "warning do not drop/dismantel"..
any help?
the one next to your handbrake is your air bag sensor i think the ecu is in the right hand side of the engine bay it is flat and cream in a white casing on the right hand side of the fuse box should be 8 connectors
The ecu is at the top right of the engine bay (as you look at it from the front), passenger side.
It is a Bosch unit iirc.
ahh.i was looking at that !..but all i could see was wire with black platsic around it..
do you have to remove it to see the make and model of it?
CocoPops said:
yeah, ikt's quite tightly packed in there.
maybe if i remove the airbox i could see??
my luck..the writing will be on the other side
