wtb engine mounts
CMF_33driver
+1 for nismo mounts, you can pick up a set of mounts for about $120, they don't have the actual mounts, just the rubber centers so you need to get them pressed out and new ones in, but ends up being a heap cheaper
$200ish should get you the whole set (including the actual mounts), but they seem to be harder to find?
*NOTE* you will get more vibration and engine noise through the car (only a bit) but it definitely helps with getting power to the ground :)
CMF_33driver
LowMicra WROTE:
"</div>
have you actually gone to a parts store and asked for a price on engine mounts (rubber and mount) for the micra?? one mount is worth $200,
As for nissan dont bother rip off artists got a $700 quote at trade for that(for 3), cheaper to get the rubber mount then press them in
I meant the Nismo ones from Japan, $200 with mounts, no way u'd get one normal mount for $200 :)
