Valve Clearance,please help
M
MrMiLK
Guest
Hi everyone,recently hears some noise from tappet "ta..ta...ta...ta.." when idling.
Wanna reset the valve clearance but not sure the spec is,anyone please give me some information.
And currently i have an idea to rebuild a 1.3 motor to instead my 1L now.However,what sort of camshaft,piston,rod,crankshaft i can upgrade?wanna make a grunt N/A March~High rev as well ^^
i think the inlets were 0.2-0.35mm and exhaust were 0.3-0.45mm? can't remember exactly.
i'll check again when i'm home.
i ordered my 14 shims from nissan that costed me bout £80
certainly sorted the tappin valves from my 1.3
i'd check the valve clearances first.
right, when the engine's cold the inlet clearances should be 0.25 to 0.33mm (aim for 0.29mm) and the exhausts should be 0.32 to 0.40mm (aim for 0.36mm).
Valve clearance
Excuse me butting in..
Feeler gauge should be a drag fit, better to aim for round numbers (0.3/ 0.4, only using one feeler gauge.
Thanks for the information guys~!BTW,i don't think it will be the timing chain noise.Is not that loud.
