Hi everybody
can someone explain me how to wire stock SR tweeters?
Do I need to buy a crossover, or can I wire them on the rear output of the stock blaupunkt car stereo?
Cheers!
im guessing they were/are splits
did they come with the car?
im 90 percent sure you need a crossover. i have a few here i will let go cheap if you want?
You will need a cross over, I spotted some bloke giving away 50 free ones on http://www.mobileelectronics.com.au/forums/index.php they are **** but fine for stock tweeters. You run a wire to the cross over and a wire to the woofer (6" speaker)
If you run straight from the head unit you wont have any adjustment for each line and will run 20w straight to the tweeter, I have no doubt you have tweeter which will handle that but if they are bright you will blow your ear drums and wont have any adjustment.
