rule's n regulations
You must have another way of getting into the car, other than a remote keyfob.
For example, a hidden button underneath a wing mirror or something. Otherwise its an MOT failure....
but if there was a button on the out side and you wer in a accident n the batt cam loose ther wud b no way to gain accsess to the inside so wudnt tha b an MOT failure?
you can have an overide system were an electrical device (battery) can be added that will brake the circuit and overide from the battery causing the door to pop open.
i have this and passes MOT fine
for the MOT though, is it true what i heard that you can just wind the window down? :/
I think if you were in an accident, the door / roof would be cut off by the fire brigade, so i dont think you should worry about that!!
RE: RE: rule's n regulations
Just make sure u re-connect the battery b4 u bring it for ur MOT! :laugh:
