Resetting ECU
my airbag light is on atm and to get i off you have to go to dealers to take the fault off the ecu
could be same for you
it doesnt matter what terminal you disconnect, normally taking off the earth ( - ) lead for around 10-15 mins will do it
Is it the same as a Skyline in that you can short two (has to be the right two!) pins in the consult port for 2 seconds? piece of cake if it's the same.
firstly dont do it, you could damage the ecu as i dont think you can do that on the k12s, the one car i know you can do that on is the terranos but it has to have the obd II port on it,
best bet (safe method) is to take it to a nissan dealer so they can plug on consult II and erase the fault should take less than 2 minutes
