Oil out turbine
CMF_SavO
I have mounted a turbine garret 43 on mine micra 1.0 but I do not find one satisfying solution in order to connect the tube of return of the oil: the oil in pressure I have not had difficulty to carry it outside from the motor, but someone knows to advise to me where to connect the tube of re-enters? Thanks
CMF_SavO
It's right to pierce in the point marked on the image?
Please, answer me... Thanks
cisco
Hi there,
Sorry I didn't see your message, I would have attached an image.
Yes, this is the correct place to tap in an oil return fitting.
Good luck!
