Micra K10 speaker help needed
Hi
Ive recently purchased a new head unit for my K10 with 1 pre-out, i was gonna use this for my sub and amp, i also was gonna add in speakers on the parcelshelf but am unsuer how to do this, would i have to connect them to the door speakers some how, and if so would i have to re wire?
i also saw a comment about changing the head unit.
i put in a wiring adapter to change it to an ISO connector but saw on here something about having to add a ground wire? is this correct? fwn
cheers
treve :)
If it turns on, then it's grounded.
I believe that most radio's ground through the aerial anyway, although I maybe misinformed.
Lol sometimes the earth isn't sufficient and adding an additional earth is a good idea. The main earthing issues IIRC was with early K11's.
