My mums K11 1.0 twister (02 facelift) has a tendancy 2 go quite stiff & a little noisey. It also often doesnt spring back 2 the central position wen in neutral.
My dad has used some additive in ther which improved it a little bt not greatly, he also fitted a new spring on 2, hopin 2 cure the spring back issue bt 2 not much effect from wat i can gather.
I was jus wondring if ther wer any known problems that cud b causin this and if posible some recognised fixes or modification that we cud perform
The ibnformation is based on 2nd hand info from my dad so if its inaccurate on my part then i apologise bt i think that was wat he was sayin.
Thanks in advance
Thanks in advance
