Id like to know how they are saw them nice and cheap on sitesI've just ordered some FK Automotives, I'll let you know how they are.
Just because it's lower doesn't mean it's stifferThey'll be slightly stiffer and 30mm odd lower... Just like all others
Yeah, I don't reckon you'll feel it much till you start dropping more than 50mm. I'm not speaking from experience however.No it doesn't, but the springs will be stiffer. Not much necessarily, but they will be.
Probally.
No problem. Just a little suggestion if you're going down this route. Spray your panhard rod mounting bolts/nuts with wd40 for a few days before. Especially the drivers side mount. I also slightly loosened the nut. This meant I didn't need to grind off the bush inner sleeve.Ah cool thanks
