Should the heater controls on my 1999 Micra SE be illuminated when the normal car lights are on? If they should be working, any ideas on how to fix this?
you shouldn't need to touch the heater matrix, once you've taken the center trim off, four screws hold the heater unit in, with these removed, you should be able to access the bulbs behind the unit.
