glowing sticker
what id do m8 is attach it to the cigarette lighter cables at the back when they plug in. and even take a live feed from the cigarette to a switch then to the sticker so you can turn it off and on. its up to you dont think the batts a good idea.
its got a controll box sso i can switch it on/off and change the speed settings...the box is connected onto the sticker by wire,,then the cig lighter socket plugs into the controll box,but its too short
You having it outside the car? You'll get done for it if so....
Anyway, why not wire it onto the sidelight loom? Would be easy to do etc :)
no ..inside the rear window tis only a small thing
what do i do then just find + and - and wire straight into the wires for sidelight..will be the rear lights so i dont have to extend it then
