FS: 14x6" Mag Wheels [vic]
CMF_Jon (2)
CMF_Jon (2)
Yep, bolts onto the bumper where your number plate would normally go.
You then put your numberplate onto the light bar. I made up mounts to angle the plate so you could still see it and then riveted it on (attempt to stop people stealing the plate) Having it angled helped with the security of the lights too as you couldn't get to the nuts.
The numberplate would normally sit flush with the light bar on the bumper and expose the light bolts making them easy to steal.
CMF_Mimz
Hey Jon, with your light did you use aftermarket switch to turn the light on/off or did you get nissan micra switch?
Also read somewhere that you bought kyb/kings combo for 600 where did you get that?
cheers
Mimz
CMF_Jon (2)
Mimz WROTE:
"Hey Jon, with your light did you use aftermarket switch to turn the light on/off or did you get nissan micra switch?
cheers
Mimz
My driving lights are all wired/relayed properly and only come on with high beam. They are switchable only when on high beam (too bright sometimes haha!) The switch itself is just a toggle under the steering column for easy access. No original micra switch is available.
