FAO admin: Forum problem/bug
B
Ben
I know FAO posts arent allowed but i think this case is an exception. If your on the main screen (where you can see all sections and threads), in K11 Body there is a topic called MOT Fail! If you click on it it takes you to K10 General! I often notice simlar things like this and then theres also the one where it says that the last reply is by someone ohter than who it actually was - for example, if titch was to make a post in a thread, then i was to follow, it would still say titch was the last and this can happen for up to like half an hour!
Actually, i noticed this to, but it don't cause to much of a problem. Bit annoying like, but usualy sorts its self out after wee bit.
i had the same months and months ago and posted about it, nothing was even said about it though. if you look at the k10 bit and the member feedback...
no need for a new topic is there? this issue has already been covered in the members area!
Dont yet know why this happens, its odd to say the least.
Similar threads
