Right - take off the door cars, and then undo the two bolts that are behind the handel. from there follow a steel rod that comes from the back of the handel into a yellow block. Pull the old handel out, and feed the new one throught the hole in the door, and also put the rod back into the yellop block. Shut the door, test, then put both the bolts back on
Titch
