dial lights
just wondering if anyone could tell me what bulbs are the ones behind the dials which you can change for the blue led ones and if it is worth it ?
thanks...
these are the ones you need, you just take the original bullbs out from behind the dials take the bulb oout of the holder and put these in, you will need to make sure they all work before putting the dash back together as leds only work one way (well mine did) you willl need to order 5 to do the dials (including the clock) and ask moddedmicra which ones you need to do your heater control unit as i never did these!
Link for you \/
http://www.ultraleds.co.uk/ultimate-wide-angle-blue-leds-driver-p-1830.html
Adam
Link for you \/
Adam
thanks il get some ordered :)
