brake booster
CMF_Mimz
» CMF Member
1300cc WROTE:
"other nissan brake booster master cylinder will direct bolt to micra? , need to replace mine...
Why? Normal one is fine. If you increase ur brake calipers to say GTir one, just change ur brake master cylinder. Why the booster?
CMF_1300cc
» CMF Member
Mimz WROTE:
"1300cc WROTE:
"other nissan brake booster master cylinder will direct bolt to micra? , need to replace mine..."</div>
I thot i hav to change the whole assembly?...,n im not tring to increase the braking just wondering if n14 or n15 will b cmpatible
V
CMF_baguete
» CMF Member
1300cc WROTE:
I thot i hav to change the whole assembly?...,n im not tring to increase the braking just wondering if n14 or n15 will b cmpatible<BR>V
No, only Primera P10 2.0 GT brake master cylinder without ABS will work on the Micra brake boost, if you want to upgrade the booster, grab a K11 ABS booster, its bigger like Rudy said.
CMF_1300cc
» CMF Member
just went to mech today and the brake booster need to be replaced, its not really urgent coz its not dying yet when i stepped on the brakes but sooner or later it need replacing, he reckconed theres a repair kit you can buy but he recommends to change the whole brake booster instead.
i have already cleaned the iav, and idle is set to 650,
CMF_Mimz
» CMF Member
pretty easy about 10 mins to remove..go to a self serve wrecker with some tools..99.99% those booster will be in the car as noone ever takes them. Then remove it..learn as u go. If u can remove it off the car then u can fit it back in. But this one is an easy job. If somehow u ****ed up just dump it and move on the the next wreck micra and start again.
Thats how i learn how to remove a drive shaft from the gearbox properly after i ****ed up like 4 drive shafts :p
