K10 micras go back to 1983, and you still see some of them on the roads! Umar's turbo's are 1987, and Ed's ST was made in 88! All still running perfectly
Will need an adaptor plate to fit it to the Micra's own gearbox and maybe custom flywheel (?). Another option is to take the gearbox from the Sunny, but then you'll need custom driveshafts or try to fit K11 shafts. Both engine mounts will have to be remade, as well as the rear gearbox mount (if you use Sunny's gearbox). Also little bit of hammer is needed to the left gearbox mount
Oh, and the Sunny's engine (E15) doesn't have 85bhp, it's 75bhp...
