4-2-1
Can u get a 4-2-1 for a 1.3 march?
Anyone point me in the right direction? :)
Only available for cars with aircon from Japan unfortunately via either Aspect, Mulholland or Maxim Works. You're talking £580, £750 and £790 respectively excluding shipping & duty, so they'll be pretty expensive by the time they are landed to your door.
so, lowrider, you are saying that Aspect, Mulholland and Maxim Works ones do not require to move AC?
it's impossible to modify an ashley/janspeed one?
and asking fo a custom made one, will be expensive?
Just to know, replacing the standard manifold with a sport one, will give you benefits at low or high rpm? (or both?) And only with this change, you can keep the ecu standard? do you need to improve air flow?
sorry for the numerous questions!
Benefits are in the high rpm, if you don´t like to rev then you have to turbo it ;)
You can keep standard ecu,no need to improve air flow..if you don´t want to :) . Not notable power increase with improved air flow alone.
thanks for your answer about benefits^^
regarding A/C, you live in finland, so probably you do not need A/C XD
here in Italy we have 35-38° C in summer...
