Craig said:torque wrench that goes down to 8Nm and some feeler blades, fitting is easy, just make sure that you keep the timing right, as for gans I would say that 10bhp is not exaggerating.
rlees85 said:from what i heard you'd be looking at between 10%-10bhp (so if you have 55bhp id say you'd b looking at a 5.5-10bhp change).
Cant help you with the timing im afriad, just have to wait for craig to return for that
Me n Zeph are going to have a go at putting 1.3 cams into my facelift 1.0 (59bhp model) on monday, will let u know how it goes if you like...
rlees85 said:yeah the timing has to be spot on or it wont run right, if you put em in completely wrong you could wreck ur engine.
rlees85 said:someone else who knows what they're onna bout becuase im not v. clear! sorry
Craig said:10 bhp is rpoughly what I would say that you would get as i got 74 bhp on rr with just the cams and a Janspeed manifold, you really notice the difference after 4000 rpm as it will pull to the redline instead of being pretty gutless.
Timing, basically put them in exactly the same position as the ones that you had taken out were in, it isn't rocket science, but when you think how many deg. each tooth on them is then you will see how you can make your engine run really badly.
Nm is a measure of the torque, the bearing bolts need to be 10Nm tight, so if yours can drop down to at least 8Nm then you will be sure that they are done up correctly.
rlees85 said:i think i have a leak from my cam cover after inspection, and oil squirting up my windscreen a tiny bit when hitting 6krpm.. (on inspection it looks like it shot out the back of the cam cover onto the black bit under the windscreen n splashed up the screen....
nice!
either way im going to re-sit the cover tomorrow, hope this will help the dodgy noise/drinking fuel problem too
edit: would like to add to anyone who is intrested, there is a big noticeable gain! It feels to pull a lot nicer & quicker and really kicks in around 4,500 rpm! (altho you can feel the difference low down too!)
