k10 5speed
hey frank?
hey frank would this work? I thought k11 boxes are different, and also if it did work, would it be a simple job to swap on in a k10 1.0 auto
nef1000 iirc did the reverse (k10 box in a k11) he said you need the r/bracket off the same g/box and he cut-n-shut the gearchange rod because the universal joint was 90deg out (but i think you can knock the securing pin out and swop the joint over)
auto to manual can be a mission tho :eek:
edit, pre98 1.0 g/box only btw
