Hi all.
Recently noticed a fairly loud constant squeaking noise whenever the clutch pedal is depressed and any gear selected, it sounds quite high pitched and as if something is squeaking against the clutch which is not normal. Car has only done 29k miles so not sure if it is the clutch but have read that it might be the clutch cable becoming slack but I am aware that it does sound like the clutch bearing could be on its way out. Anyone had any similar problems or know any solutions to my problem?
Thanks in advance
Thanks in advance
