Clutch replacement
New Micra K11 owner here.
The clutch pedal is high and is noisy (squeaking). Tried WD40 but no joy. Two garages have told me I need a new clutch, so...
A couple of questions:
  1. Does £300-350 sound a lot for the work?
  2. Will the car fail its MOT if I ignore it?
No way would you pay that for a new clutch (!)
I would expect to pay around £140 at the most.
Have look at the adjuster on the end of the cable first buddy, try to do that first to see if it makes a difference.
If you have no movement left then it is a new clutch.
