hehe the force is with me
lol good plan, always get more than you need
i'd recomment you get more resistors too because the wires are quite thin and they break easily. i bought 100 of them and i've already run out lol, mainly because i thought i had so many i kept wasting them lol
for the load equilisers you will need two, one for each repeater...
you will only need them if your indicators flash too fast which i don't think they will because you are only doing the side repeaters. if you decide to do the other indicators in LED then you will need them.
they are basically a large resistor which simulates the resistance of a bulb but because of that they get as hot as a bulb. but this should not be a problem because the lights you are using them on are flashing ones and not constant on (like in America)
really i don't think you will need them but they are useful to have anyway
something useful to know, if you don't already is that the flat side of the LED is negative... which i think is the longer leg...
also i'd wire them in parallel
good luck mate, let us know how you get on
