Hi guys,
Had a quick poke about whilst my front wheels were off and notice my front spring can rotate freely 360deg by hand, once the weights on the strut naturally its all compressed & its sitting in the perch correctly but...
I wasn't around when the struts went on, they are still captive (just) im a little concerned as the springs not under any compression when the struts assembled which i found a bit odd, shorter dampers needed maybe?
Its a 55mm lowered tarmac spring btw
