A MOBILE car audio installer in Perth?
CMF_Micra_King
h45e, So you got that unit then? it should be easy as to install as it should already have all the factory connectors attached to the new unit? and all you need to do is remove the old unit and plug in the new one. The GPS antenna wire needs to go up through the dash and have it up along the top of the dash or up along the pillar (Under the plastic) if its long enough. Where in perth are you anyway?
