Single grill
I was going to make the two small girls on the bonnet into one long one.. What should I use to put around the edge after I have it done? Iv seen te link on here before but just can't seem to find it again :/ if any one could give me te link again it would be very much appreciated thanks :)
If you've got two small girls on your bonnet, I definitely wouldn't interfere with them!
This kind of thing?
http://pages.ebay.com/link/?nav=item.view&id=191053258129&alt=web
this :p got a spare bonnet tho so if I f**k up it's ok :p and why yes I think that's it haha thanks :)
But I'm having sort of the same problem as you, I understand that some sort of door protector can be use but I don't know whether (when I come to do it) I need to grind down the 90° lip around the double grills or not, I'm not sure if that sort of door trim will fit over it or not
Ah ya I understand. I'm getting a spare bonnet to do it on just in cause I F**K it up just to be on the safe side yano? :)
Yep, and probably only in Japan. There are other people who have done single grill conversions to facelifts but they have filled and painted rather than using rubber trim... Although I don't want to fill and paint...
Just asked him again and got a reply. He did cut the lip. And thinking about it, its not much of a problem really just need to keep the bonnet cool when cutting it so that the paint doesn't flake. And if you fo cut it, it makes fo ding rubber trim a lot easier
