New Repeaters Facelift
Igloo
I've just bought some new facelift repeaters, But they dont fit :(
Attached are some pics
there designed to fit the late k11's and almera's. The whole in the wing is the same size as the repeater, with it attaching to the wing using the clips at either side. If you can find a way to attach it to the car then you need to find a late k11 in a scrappy and steal the repeater plugs.
These can be got to by detaching the arches and then unclipping them from the wiring loom.
Mike
Mike,
They fit fine, If what you mean by a late k11 is a prefacelift, i'll see if i can ge one from a scrappy and just combine the loom's.
Just annoying as these are advertised as micra k11 facelift (98 to 02) and they don't fit direct... Ah well.
If anyone else knows another way or something, please post :)
Cheers,
Igloo
Update:
Been to look at a pre-facelift micra in a scrapyard, The connector blocks are the same :down:
If i got the connector block of an almera would that be a direct fit? I can then splice the two cables together and bobs your uncle.
Or is there a connector block to connect the two?
Igloo
link
Are the ones i bought. Nevermind. I'll put em back on ebay i think.
What are the reg plates for 98 - 00 ? t-x?
