Next step after (or while) my block is getting cleaned up is to get my hands on a cheap 1.0L block so I can rob it of its pistons. I need one with the cylinder head also as I've decided to try my hand at a little porting and polishing and I want a spare to practice on.QUOTE]
where abouts in the midlands are you located, if you can get to chesterfield (new tupton), then you can gladly take a cg10 off my hands, free of charge. it's a complete engine, but without cam cover though. i threw out my old cg10 pistons, so i can't confirm measurements.
and for the links, just copy the web address at top of page, using right mouse click 'copy', then right click 'paste' it into reply box.
Incidentally, I've been into a few websites that might interest you (and others) but being something of a Luddite when it comes to computers, etc., I'm not entirely sure about posting them as links so all you have to do is click on them to bring them up. I know it goes something like but how do you get the website into the attachment bit without having to type the whole thing out (some are quite long)? Or is that the only way?
S
http://www.sa-motorsports.com/diyport.aspx
Thanks, rather do that than type it all out.
Generous offer, Swiper, I'm in Nottingham and will do a Multi-Map to Tupton.
S
then the web address then will get your links done.
Swiper, any chance I ould have th crank pulley off that 1L?
Poo, oh well, I'll keep searching.
Soix, IIRC the gasket is 1mm thick, you should really do a test with the gasket in place and also do the same with the flat-tops.
Craig
So, how much lighter? Couldn't be more than a few ounces. But, with the 1.0L Facelift flywheel I can see where it might make a difference.
Yes, happy to do it with the gasket and the 1.0L pistons because I like this kind of thing and, I'll need plenty of practice getting the cam timing right.
Craig, are building up something similar?
S
Assume this engine has the pistons still in it and the ones you got rid of were from another block?
Definitely need a hand, doubt I could get it into the boot on my own. Almost ruined me just getting one out. Would weekend of the 29th/30th be better, or do you prefer weekday? Also, if this is too much of a hassle okay to retract offer.
S
Okay, great, understand anytime on weekends and after 5:30PM weekdays.
I'll post or pm a definate date.
S
