WTB k11 gearbox melb
CMF_Mickb
» CMF Member
Doesn't look like there is any lying around, you could try wreckers? but then you may end up with one just as bad. Cheaper if you remove it from the car yourself etc (pickapart anyway)
CMF_Mickb
» CMF Member
Rowstar - I have a bearing set for a k11 GB here, I'm sure I can identify which bearing is which, then you can order it from a bearing shop.. how about you get a few prices from garages on pulling the GB, opening it up, replacing the bearing, and refitting..
If I was still in Melb I'd give you a hand :)
CMF_woohoomobile
» CMF Member
no manual K11 at kilsyth pick a part, was there today.
sounds like i need to do the imput shaft bearing in mine too.
noisy all the time, goes quiet when i push the the clutch in.
ill see if i can find a box in gippsland to re build.
part numbers for bearings would be great!
