Am using top feed rail from coil pack
and 317 cc injectors fit in tight am happy no cut or welding need, for this you will need spacers for the 2 bolts holding rails down. And 4 plastic tubing to go in the inlet manifold and just sits in o rings and into the injectors. so it's tight fit.
It's cheaper and less mods needed
Meaning doing this you will lose your idle valve coz it catches on the rails
