Sub and amp
You want a high amp cable from positive on the battery with an in line fuse of a correct rating they do come with amp wiring kits.
Run the wire through the spare fire wall grommet under the dash under the edge of carpet... corner of carpet can be lifted by removing the passenger door seal.
Then Under the back seat to the boot leave as much length as possible as this can always be trimmed for a better fit later...
This positive cable connects to the amplifier on the positive port...
Then run your earth or ground from the negative of the amp to a bolt in the boot with a correct connecter there are plenty that can be used for a ground.
You should then find an amp control wire connect this to the back of the head unit there should be an amp wire hanging out the back of your head unit.
This wire then needs to follow the same path as your live wire through the car to the amp as before...
There are 3 ports on the amp + - and amp control...
So place this smaller wire in the last remaining of the power ports.
You will then have the sub out cables same as before back of head unit to the sub following the same path as before.
These have stereo adapter plugs so just plug in.
Lastly connect the amp to your sub with good quality speaker/sub cable.
Tidy all carpet back and Enjoy mad bass ;)
High amp wire from the battery needs to go through the spare rubber grommet under the bonnet on the firewall pop a hole in the middle of the rubber and feed the wire through till you can pull at it from the inside of the dash :)
You won't you can completely remove the grommet if this makes you feel better about it... could be easier to pass the cable through thinking about it :)
Just done my sub it's easy to run cables,and car comes apart in seconds,just want to upgrade back side speakers was thinking putting 10 inch in there,my 12 inch was to big,so put it in a box in boot,sound good,just a few rattles from plastic but we'll happy,for now,
