Hi guys will stock computer read 5psi turbo swop
1995 probably has distributor and HT leads.What yr is pre coil pack it's 95 with a dizzy could I put bigger injectors and run fuel regular
Coil packs don't have dizzy on side right sorry for silly question mine looks similar but different
Both motors are pre facelift no coils one was air-con all add one other was not both blocks say 1.3 still looking at boosting will I need to lock dizzythey changed out the engine on the 1.3 litre
1.3 litre:
CG13DE engine was in pre facelift micras 1993 - 1997
CGA3DE engine was in facelift micras 1997-2000
CGA3DE facelift coilpack (micra k11c) had 1 catalytic converter instead of 2, and was running on coilpacks 2000-2003
1 litre:
CG10DE - 1 litre version in every k11 micra from 1993 until 1997
CG10DE facelift - 1 litre version in every k11 micra facelift from 1997-2000, had 7 more horsepower than the 1993-1997 engine
CG10DE facelift coilpack (micra k11c) - 2000-2003
