goldstar0011
So now that BEF is just sitting on my drive due to sill rust, do I patch, use the pattern part to replace a section or replace the whole sill with the part?
The sills already have had so patching when I bought it and even that is a little messy and looks to have a rust issue. As the rust isn't just on the flat of the underside which happened before, the patch job I had done warped the curve and was unsightly, had to fibreglass the area and is still not so good.
The pattern part is this
so the curves are still gonna be there, the hardest part will be making sure it fits the rear panel where it'll be cut (a challeneg it is then)
I know the whole sill replacement will be a biggish job for a beginner welder but I'm assuming it's easier than patching (changing whole frontend is easier than a crossmember change)
Also there are some small holes (can just about get a finger in) on the inner sill/floor panel, is it ok to treat the rust, weld a peice from the inside (if I take whole outer sill off) then f/g the hole over?
Advice is much appreciated
