Having trouble finding a few bits, these being:
PCV filter
Throttle Body Gasket
The little rubber seal/ring thing in the idle control (?)
Basically gave the car a full service and the only part I didn't change was the PCV filter as I can't find one and nobody has any clue what one is, let alone where to get one. My local motor factors said it must be a dealer only part? Can't find one on ebay?
With the other 2, wanted to clean the TB/MAF as I had problems with high idle, which to be honest I'm not completely sure how to go about yet? But Haynes says I'll need a new Gasket? Again, motor factors said this is a dealer only part and I can't find one?
I gave the TB a quick clean in situ, took the idle control off, gave that a clean and the seal/ring thing appeared to have been caught somehow? That's freed up now and does appear to have improved things but it does have a little nick/tear in it so wanna change that... Again, no luck!?...
I've had a search on here for TB cleaning guides but it just throws up loads of threads that even have mention of TB in them?
PCV filter
