I'm replacing the front left CV joint gaiter/boot on a Micra Twister, K11, 16v, 1998, 1.0
The manual is confusing me and I'm not sure I've gotten all the parts right. Also, it seems like a lot of hard work and I've been told I don't actually need to remove the driveshaft
Could anyone have a look at the photo and labelling and make sure I've gotten the parts right and help with the questions below
This is what the manual says...
Loosen the driveshaft nut
Jack it up
Take the wheel off
Take the driveshaft nut off
** I've gotten this far and looked around a bit and then had a cuppa to reward myself - the nut was hard to remove
Remove the driveshaft
Which involves
- Drain the transmission oil
- Undo the caliper guide pins (A in the photo listed at the bottom of the post) and remove and suspend from a wire
- Undo the track-rod to steering arm nut (C in the photo)
- Undo the bolts holding the hub carrier to the suspension strut (E)
- Pull the hub carrier outwards while pushing the driveshaft through the hub
- Pull the driveshaft from the transmission
When I've got the driveshaft out
Measure the boot length so the new one goes on the same length
Loosen the gaiter clips and slide it towards the center of the shaft
Make alignment marks (driveshaft to CV joint)
Clamp the driveshaft and tap the driveshaft inner race outwards using a mallet and soft metal drift. This will force the retaining clip to contract into its groove and enable the join to be removed from the shaft
Slide the gaiter off and remove the circlips from the end of the shaft if necessary
Scoop out the grease and clean gaiter and shaft
Slide the small gaiter clip onto the shaft
Fit new securing clips (square section circlip and round section circlip).
Stick the joint back on the shaft (with corret alignment)
Tap it on until the clips hold it
Pack with grease
Slide the gaiter on then the large gaiter clip
Set the length of the gaiter as the old one was
Tighten the small gaiter securing clip
Refit the driveshaft
Jesus Christ - why don't I just rebuild the whole car!
The questions I have are
1. Have I got the labelling right (A, C, E)
2. I take it I leave B (the thing mounting the rest of the brakes [caliper mounting?] onto the hub carrier) and D (suspension lower arm to hub carrier) alone right?
3. It says I need new circlips. How do I order these - do I just call and ask for the circular and square groove circlips that hold the front left outer gaiter on a micra twister 16v 1998 etc etc
4. Is there an easier way to do this without taking the driveshaft out (well really - without having to undo all those bolts that I just know will be seized). If there is can you give instructions, or refer a link if I've missed the instructions elsewhere
Cheap as chips is a priority (i.e. I can't just go buy a new driveshaft), as is getting it done by next tues (to resit the MOT cheaper)
Thanks in advance for any help
Jack it up
Take the wheel off
Which involves
Pack with grease
