rear window washer
im not sure tbh, most cars have 2 pumps, 1 front, 1 rear and if the front works and sprays water fine and you definitly cant even hear the motor pumping noise when u push the rear switch the fuse seems the most likley item to check :D, have a look, check that first
but you will find in the recent cold snap the 'freeze that action' has a nasty habbit of damaging washer pumps and connections in the washer jet hoses if u havnt been using proper screenwash with the anti freeze additive
