Hi guys, Im hoping someone can help here as im a little stumped!
I got into my micra after work yesterday and there was nothing, turn the ignition and all you hear is the usual buzz (nats i think) then when you go to the start position you just hear a click. Its as if theres no power getting to the starter motor.
Messed around with the battery connectors, started fine. Got home, tried again - no go. This time even taking the connectors off, cleaning them up and putting them back on has done nothing. Good spark from the connectors.
So far ive tested the following:
Turned headlights on and tried to start, they stay bright, no difference.
Side lights on and start - they get brighter? Not sure if this is normal?
Heater on with fan blowing - when the key gets to the start position the fan turns off, normal or not?
The nats light does go off on the dash after the key is checked so I dont think its that.
Any ideas? Cheers.
Any ideas? Cheers.
