M
mmikra
My 93 Micra has taken to random hiccupping! It feels as if the ignition has
suddenly been turned off. It nearly always happens (when it does at all that is)
when I press the accelerator to pull away in first. Lately it taken to happening
in any gear!
Today, with engine idling, I jiggled a rubber pipe that sprouts form the
camshaft cover - and the engine hesitated. I couldn't make it happen again
though and I think it was coincidence.
There's quite a vacuum "whooshing" noise when I take the fuel filler cap off – a clue maybe?
I posted a newgroup about this (before I found this forum) and got these replies…
Possibly throttle body - several hundred to fix! Unless its just the
electrical connector a bit loose.
My daughters does the same - replaced plugs, carbon canister etc.
We've had similar problems with a Peugeot 1800 406 petrol and a Proton 1.5 petrol - turned out the MAP (Manifold Absolute Pressure) sensor had got 'old' - this is the sensor that tells the fuel injection how much
pressure/vacuum is in the inlet manifold.
Any help much appreciated.
tia
in any gear!
tia
