Hi folks,
I am looking for some opinions if I may. I am pulling my hair out at the moment with the wifes car. A 2004 Nissan March.
In a nutshell, its overheating. There is no temp gauge fitted, just a red light that comes on when its too hot. It happens at slow speed. Perfectly fine on motorways. Not leaking any coolant. If the light comes on around town, it will go off again with a bit of driving and airflow.
We have tried just about everything so far and I am stuck. This is what has been done so far.
So we just got the car back from the garage after having the radiator fitted. Expected that to cure the problem but although it has improved slightly the problem persists.
Really at my wits end with it now. Kinda hoping it will spontaneously combust. It looks like we will just put a new engine in, but at at cost of about €1,000. Does anybody have any suggestions before we do this?
Any suggestions would be greatly appreciated
- Sniff test completed. Tested negative.
- New radiator cap fitted.
- New thermostat fitted.
- Water pump removed and inspected. Perfect working order.
- Fan working correctly and switching between both speeds.
- Heater in car works perfect so the matrix is ruled out.
- Radiator was removed and tested. Was showing as partially blocked so a brand new one has been fitted.
