Your adjusting the self adjuster, which is wrong, that automatically adjusts as the shoes wear down. If yours aren't automatically adjusting then get em changed or freed up and serviced
The correct way to adjust the handbrake is at the cable. Not sure on a k11 its either a 10mm nut by the handbrake or a threaded clevis adjustment box under the car just in front of the fuel tank
