CMF_turbo march-rolling shell
» CMF MemberGROUP BUY CLOSED! will the people below please forward payment. thank you.
hey guys... well after a few enquiries as to if i'd be able to get some adaptors made up to fit the sr20 throttle body to the stock cg13 plenum.. the answer is yes.. i can get them done. The machinist i use has agreed to make up a batch if we can get the numbers... basically its a sandwich plate which allows the use of the sr20 throttle body to be directly bolted to your stock cg13 plenum. only other thing you'll need to do is make up a bracket to hold the throttle cable (easy)... yes you can use your stock throttle cable too! you will need a airflow meter and a safc/emanage to run this setup. or if your already using an aftermarket ecu this will just bolt straight on.
ok.. if we can get 10 ppl he can do them for $120 + delivery which will probably be around $5 to most of aus.
if we only get 5 people the price will be $140 + del
these will be cnc machined from solid blocks of alluminium. i've included a picture of a nismo adaptor.. the one i will be getting made will do exactly the same thing, bolts will be provided with the plate... so lets see a show of hands.
group buy list:
1. mickeybbb***paid
2. sportsclassic ***paid
3. tony***paid
4.d1cefiro ***paid
5.sikk11*** deposit paid
6.jaxx *** paid
7.smidge***paid
8.
9.
10.
btw. overseas buyers/international postage not a problem
![](/proxy.php?image=http%3A%2F%2Fimg143.imageshack.us%2Fimg143%2F8319%2Fdazmo001ou7.th.jpg&hash=0ab70d0690dd51e8c20c1d84ce56bc30)
group buy list:
1. mickeybbb***paid
3. tony***paid
4.d1cefiro ***paid
6.jaxx *** paid
7.smidge***paid
8.
9.
10.
