Hi all, I wanted to change the fuel filter on my k11 2002 and proceeded to open my Haynes manual. The manual seems to go the long way around to do this? I then checked on this site and found out it is so easy. I removed the fuse for the fuel pump then started it up (it soon stopped) then undid the two clips on the filter itself. I then eased the filter out of the housing and pulled the pipes off being careful to catch the contents of the filter which weren't too clean! Then put new filter in, pushed on pipes, tightened the clips and restarted the car job done! I think in the future I will check on here first before using my Haynes manual. Use to trust Haynes but seem to find a lot of faults with them these days?
