so I fitted a GA16 airbox on the weekend and had 1/4 of a tank of fuel got in the car today after it not being used since fitting and it was down on the red. wheres my fuel gone :/ any ideas ???
my only idea is that because I removed the charcoal canister and just blanked off the pipes but didn't remove them fully and maybe fuel has got stuck in there or something
That doesn't seem alot? Can you remove charcoal canister? Surely its there for.a reason? You just need to move it to fit the bigger airbox, like rotate 90degrees on one of its bolts...
I was thinking about moving it tbh like rotating it and see if that solves the issue and yeah you can remove it. i think it would have been better if i had done it fully rather than half heartedly
