doing the clutch cable?
wonder if anyone can help me. i'm trying to find out how easy it is to try and adjust the clutch cable myself. dunno where to even start looking so if anyone can help in finding any info on the subject it would be brilliant and much appreciated. its on a standard K plate K11. the wifes car for her homecare juob so pretty integral to her being able to get to clients. has anyone got detailed plans of how to get this done? cheers guys :grinning:
real easy, just need a size 10 spanner. the cable/lever mechanism is just below the battery tray. on the mechanism there's a large thumbscrew type adjuster to adjust the cable tension and a lock-nut (hence the size 10 spanner)
removing the battery tray allows easier access but not essential.
simply loosen the locknut, adjust the thumbscrew and check the clutch pedal feel, then tighten locknut.
