micras69
Deactivated Account
grrgrrgrr
since reciveing the micra there has been a list of things gone wrong and now its cooling an starting![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
sice owning the car the rad fan hasn't once came on :doh: (carnt belive i didnt notice) and the engine temp guage is working but reading only a 1/4 of the guage (not the usual half way mark)
when turning the car over it takes a wile to start unless i give it some gas? but then i can turn it off and try agen an will start no problem??
so tryed fixing it.....
first of ran 12v to the fan.....works fine.
cheked all fuses iside and in the bay.....all is fine.
replaced the temp sensor and sender... below the dizz/ behind the thrmostat.
replaced the thurmostat and housing.
replaced the clips to censors (loom side)
replace the dizzy and leads
replaced the plugs
replaced the TB
replaced the fule pump
replaced the fule filter
replaced the fule rail and injectors
and non of this has worked still takes a wile to start and fan still isnt working and im now getting to the point were im just going to cange the engine
somone please help me :wasntme:
replaced the plugs
replaced the TB
