euro_micra
Matt :)
What are the differences(if any) between the 1.0 and 1.4 coilpack engine heads? I know the 00-03 CGA3 has a slightly different valve-train setup than the 92-99 CG13 & CG10, but what about the 00-03 CG10?
The reason I ask is because I'm looking to create a under-bucket shim set-up for some wilder cams. The CGA3 has a shimless bucket so thats perfect, but they're a lot less common than the 1.0 coilpack. But I can't find any actual evidence to show if they're the same or not. And the part numbers seem to overlap between all K11 engines.
Matt
Matt
