The clutch you use depends on your car. Prefacelift 1l use 160mm, post facelift use 180mm. A 180mm clutch won't fit a pre-facelift 1l and a 160mm clutch won't fit a facelift 1l
Ahh that explains it then, looks like a 160mm clutch, 1.3 cams, ga16 injectors and a small turbo then ga16 throttle body isnt a direct replacement at all
